De-Badging a Z28
Old Mar 3, 2005 | 04:54 AM
joey93turbo's Avatar
De-Badging a Z28
What's it take to remove the emblems from the sides and the rear? are they just glued on or are there holes?
Old Mar 3, 2005 | 06:26 AM
teke184's Avatar
Re: De-Badging a Z28
some kind of double sided tape i think...NO HOLES
please don't tell me you wanna make your car look like a v6?
Old Mar 3, 2005 | 06:29 AM
Kris93/95Z28's Avatar
Are you trying to add a different type of badge?
Old Mar 3, 2005 | 08:01 AM
enzo1267's Avatar
probably going for the sleeper look. but anyone would have to be stupid to think a six would sound like an eight!
Old Mar 3, 2005 | 08:54 AM
RamAirTA95's Avatar
There are no holes.
Easy to do:
1. Heat up emblem. Either park outside on a hot day, or use a hair dryer.
2. Take a piece of fishing line ang gently "saw" back and forth between the adhesive and the car.
3. Rinse and repeat for each emblem.
Old Mar 3, 2005 | 09:14 AM
kefkafloyd's Avatar
Might want to use some Goo-Gone too to get any leftover stuff off.
If he's going to be painting the car, taking this stuff off and then re-sticking it with new tape is better than masking it and painting it, IMO.
Old Mar 3, 2005 | 04:55 PM
Z95m6's Avatar
Originally Posted by RamAirTA95
There are no holes.
Easy to do:
Be careful when you do this though if you want to keep the emblems. I did this on my car and broke two of them. Its not really a big deal because i installed 69 z/28 emblems on mine.
Old Mar 3, 2005 | 05:38 PM
hatredizm's Avatar
If the car is going to sit overnight after you remove the emblem. Smear some peanut butter where the glue was and it will simply wipe off the next morning.
If you park outside though, beware of dogs or animals eating it off your car
Tony
Old Mar 3, 2005 | 05:45 PM
Bayer-Z28's Avatar
Yep, Bug and tar remover works awesome too.
Old Mar 3, 2005 | 05:52 PM
97BBlackZ's Avatar
I never really had any luck with a hair dryer. I would prefer a heat gun if you can get one. I used one and it came of REAL easy.
But make sure not to get it to close to your cars paint or blast it in one spot for awhile
I would say just hold it 6 inchs away and keep touching it tell it feels hot enough.
Old Mar 4, 2005 | 12:09 AM
350TPI5SPEED's Avatar
i put masking tape around the emblem, then use a guitar string(thinest one you can find) and just go right under the emblem. ive done this a few times and did it on my z in oct. this way there is no heat involved that could hurt the paint.
hope it helps
jay
Old Mar 4, 2005 | 01:05 AM
97BBlackZ's Avatar
hope it helps
jay
I tried something like that with my old fender from my wreck to get the side molding off and the wire ended up going into the side molding. But the emblems are alot harder then the side moldings so there might not be a problem. Just be careful.
Old Mar 4, 2005 | 09:02 AM
you could damage the emblem. but if you hold the guitar string as close to the body as you can, you wont have to worry about it. and scratching the paint wont be an issue either if you use the masking tape.
Old Mar 4, 2005 | 12:48 PM
Joe Bellman's Avatar
I did the same thing to mine a few years back. People comment on it all the time. I should have done it right and put 350 emblems on the fender in front of the front wheel too.
Old Mar 4, 2005 | 01:18 PM
Z06Z28's Avatar
Goo-Gone and fishing line worked perfectly for me. I took the fishing line and pulled it under the old emblem as close to the emblem as possible so I wasn't scraping the paint. If your saving the old emblem, I would go very slow. Left over was the foam rubber to be rubbed off with Goo-Gone. Carfeul not to scratch and cause swirl marks on your paint and make sure you rinse that Goo-Gone off the car. Use soft sponge and make sure you clean the surface really good before mounting a new badge. I recommend 3M double sticky Industrial strength if you plan on mounting new badges. With my new badges (if you run into this) I had to dremel off the posts and then sand the backing, then used JBWeld to fill the grooves/rough backing and then smoothed it out. It was perfect for the 3M tape to stick to. No problems yet.
Here's the badges I put on.
rear
side
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
