Daytime running light - bulb replacement
Old Oct 14, 2004 | 10:40 AM
'99 SS's Avatar
Has anyone replaced the bulbs in the daytime running lights?
I stopped at the dealer and purchased 2 bulbs (to replace both R/L), and was told it would cost about $24 for them to install them for me!
I removed the 2 screws on the tray underneath the front of the car to access the lamp, but could not locate the bulb to replace.
Any ideas?
Old Oct 14, 2004 | 12:44 PM
FastrDamnit!'s Avatar
Re: Daytime running light - bulb replacement
You can access the rear of the DRL/Turn signal assembly from above, just remove the headlight assembly (fairly easy).
Old Oct 14, 2004 | 03:43 PM
'99 SS's Avatar
Thanks. I didn't think of that.
Wouldn't that cause an "alignment" problem with the headlights when I reinstall them?
Thanks again
Old Oct 14, 2004 | 04:08 PM
steelerfan's Avatar
Nope,no alignment problem at all,I've done both of mine already,in fact if you want,bring them with you Sat & I'll give you a a hand if you want.
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
isimplyexist
Mar 25, 2004 08:06 PM
30thZ286speed
Aug 3, 2002 04:54 AM
