Cylinder 6 Misfire??
Old Mar 28, 2006 | 07:42 PM
khojo16's Avatar
cylinder #6 misfire is wut my obd2 code reader says (P0306)...the connection from the wire to the spark plug is fine...checked it a million times and the wire is completely shielded with fire sleeving...my next thought is that the connection on the opti end is not on well (which i think it is), or that wen i crimped the opti boot and terminal on that end...that it didnt get a good contact...anyone else have opinions on what i should check or do in this situation??
Old Mar 29, 2006 | 06:20 AM
Dave89IROC's Avatar
Re: Cylinder 6 Misfire??
check the opti end, then check the plug(switch with a different cyl,. see if the miss moves), then check compression, then fuel injector
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
