custom steering wheel (airbag light, security light)
Old Apr 8, 2008 | 02:59 AM
nekvooli's Avatar
1999 camaro (euro). Custom Simoni Racing steering wheel. Both airbag and security lights are on.
How can I fool the system?
I want the passenger airbag to work properly...
I've done it once, but it was Peugeot. Put 2 ohm resistor in the circuit (instead of the airbag). Worked.
Will 2 ohm resistor do, or do I need a different resistance for the resistor?
I've already read similar threads, but didn't quite find what I was looking for.
Old Apr 8, 2008 | 08:49 AM
19z28camaro02's Avatar
try the resister, that may or may not fix the security light. If it doesn't, .......pull the bulb in the cluster.
Old Apr 8, 2008 | 01:14 PM
theratdude64's Avatar
The security light can probably be bypassed with a Resistor that corresponds with which VATS Pellet you have. Theres 15 different ones. You can use a volt meter to figure out what voltage of Resistor you need, or if you don't actually have the Vats key *like me* I found from the dealer what Number pellet I need, and a chart shows what resistance you need.
And if you search for airbag removal it'll bring up a few threads talking about what resistor you need to bypass that. That should take care of both lights
Old Apr 8, 2008 | 01:48 PM
nekvooli's Avatar
ok. I finally got, what I was looking for
REVZ wrote:
When you pull the airbag put you need 1.6ohm of resistance to fool the computer into thinking the airbag is still there. I used two 3.3ohm resistors in parallel on my 2002.
when I get it fixed, I'll let you know. thanks for help
Old Apr 15, 2008 | 04:31 AM
nekvooli's Avatar
bought 1,6ohm resistor (about 0,3$), installed it and it worked!
thanks for help
Airplanedoc
Feb 1, 2015 07:14 PM
fpete1992
Dec 11, 2014 03:51 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
blac94Z
Dec 2, 2014 12:09 PM
