A/C's not cold and it's HOT outside
Old Sep 26, 2007 | 03:45 PM
Hood_Lum's Avatar
My A/C was blowing warm air so I released all the air from the low side. There was no refrigerant left, just air. Then I used the recharge bottles you spray in from Autozone. The gauge on there is in the blue which is suppose to mean it's in the right range. However, it's still blowing hot air.
Are our car's A/C suppose to be at a higher or lower range than 35-45psi?
Old Sep 27, 2007 | 08:42 AM
scottso's Avatar
Is the compressor running? I guess so since you put refrigerant in but confirm that.
If you exposed the system to atmostphere you probably introduced moisture - compromising performance. I did this to replace a leaking schrader valve - got A/C back - pretty good - but not frigid. If mine holds pressure I am going to have it vacuumed and properly filled next year.
I also understand the dryer needs to be replaced any time the system is opened.
Old Sep 27, 2007 | 03:01 PM
Hood_Lum's Avatar
Now that you mention it I might have a leaking schrader valve as well.
When I unplug the can from the valve I see some refrigerant bubbling very slightly.
MikeWhitener
Aug 2, 2015 06:17 PM
jbc3
Jul 28, 2015 12:24 PM
Xiantyl
Jul 21, 2015 05:42 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
