Could the starter motor be causing this noise?
Kind of a grind/rattle when I shut off the car. Sounds like its coming from the passenger side. Possibly under the car.
Its not the torque converter. I tightened it up and put loctite on the bolts. The bolts had backed off a bit in the past but they are snug now and the noise remains.
Re: Could the starter motor be causing this noise?
Exhaust rattle maybe? The starter solenoid shouldn't be engaged when the key is not in the "start" position and therefore not even touching the flywheel. I suppose it's possible though.
squarehead
Nov 21, 2014 08:02 PM
