coolant light on
Old Jan 29, 2007 | 05:43 PM
reamo04's Avatar
coolant light on
well guys, i was driving and my low coolant light came on.
Immediately pulled over and checked the coolant level, it was fine
What would cause the light to come on since the coolant is not low?
Is tehre a way that i can reset the light to see if it stays off?
Old Jan 29, 2007 | 05:50 PM
2001NBMZ28's Avatar
The sensors go bad all the time. You can take it out and try and clean it up, replace it, or just unplug it and the light will stay off. Sensor is in the radiator so remove the radiator cap and check the level with the car cool.
Old Jan 29, 2007 | 05:57 PM
reamo04's Avatar
wheres the sensor located at in the radiator?
Ive never had to replace one or anything, so dont know what to look for.
Thanks for the fast response though.
At first i thought "oh crap, headgasket...wait, yes, time for rebuild" but no such luck lol
Old Jan 29, 2007 | 06:12 PM
RE AND CHERYL's Avatar
Did you pull the radiator cap on a hot engine??? Or just look at the overflow??? If you looked at the overflow you need to check the radiator level AFTER the engine cools.
The low coolant sensor is located about 6 inches down on the RH end tank.
Re'
Old Jan 29, 2007 | 06:20 PM
2001NBMZ28's Avatar
http://shbox.com/1/low_coolant.jpg
Old Jan 29, 2007 | 06:41 PM
reamo04's Avatar
Re'
I checked the "coolant tank" on the passenger side of the motor while it was warm. I have not pulled the radiator cap yet, because since it was warm i did not want it going all over
Old Jan 30, 2007 | 11:02 AM
jlmeraz's Avatar
ive had two camaros with high miles and the sensor went out on both its located on the passenger side of the radiator just under the radiator cap (im doing this from memory so i might be wrong )
Old Jan 30, 2007 | 11:14 AM
moparman's Avatar
Take the battery out, and you can get right to it.
Old Jan 30, 2007 | 03:31 PM
reamo04's Avatar
i unplugged the sensor, problem solved lol.
Now I just need to remember to plug it back in when i change out radiators and get a new sensor lol
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
Apr 16, 2015 05:50 PM
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
