Coolant leak, maybe water pump. Need help
Old Apr 8, 2015 | 11:50 AM
Blood type Z28's Avatar
I noticed the other day my car was leaking coolant, when I got home it blew the coolant everywhere. I think it's the water pump gone bad. Is there anything I should look at replacing with the pump? My Camaro is a 97 Z28 with 69,xxx miles. Any advice would be great.
Old Apr 8, 2015 | 01:30 PM
Re: Coolant leak, maybe water pump. Need help
The water pump has a very small weep hole. That will not blow coolant everywhere. It would drip on the distributor, which is a whole 'nother problem.
If you can't see the source of the leak, do a system pressure test before assuming you need to replace the water pump.
Old Apr 8, 2015 | 02:05 PM
moparman's Avatar
If it blew coolant everywhere, I'd check all the hoses.
Old Apr 8, 2015 | 04:20 PM
Sorry if this is a dumb question but how do I do the pressure test?
Old Apr 8, 2015 | 04:46 PM
You borrow or rent a pressure tester from an auto parts store. The pressure tester is an air pump that tightens onto the flange where the radiator cap would normally attach. You pump up the pressure in the radiator to the pressure cap rating (18 psi for your LT1). and watch to see if the pressure drops over time. If the pressure drops, you need to start checking the hoses, radiator, water pump, heater core, etc. to find out where it's leaking.
Here's an example:
Old Apr 8, 2015 | 11:34 PM
Thanks for your help, I'll check it out.
timmy39120
May 2, 2015 05:12 PM
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
Cam28_boy
Aug 6, 2002 08:40 AM
