Changing Brakes
Old Jul 11, 2004 | 12:54 PM
toegead93's Avatar
Changing Brakes
I'm doing the LS1 brake upgrade. The install directions I'm using say I need the following :
Floor Jack
Jack stands
12 mm wrench
15 mm wrench
16 mm wrench
18 mm wrench
C-Clamp
Flat Stock
Loctite Thread Locker
Brake Cleaner
Whats a "flat stock"
I have everthing else. Thaks.
Old Jul 12, 2004 | 08:27 AM
RENE95Z's Avatar
Stock is term used for a pole of material (alum, stainless, steel, etc.) Basically it is telling you that you need a flat piece of metal that you can put between the c-clamp and the piston when compressing the piston back into the caliper to keep from damaging anything. Kinda of like putting a block of wood between the jack and the car to keep from damaging the car.
Old Jul 12, 2004 | 12:50 PM
HBHRacing's Avatar
or you could use an old pad... or a real caliper piston tool. either way it will work ok
dluna333
15
Mar 13, 2015 12:30 PM
captcorvette
Mar 7, 2015 12:37 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Jul 4, 2005 05:00 PM
