Car starts then dies immediately
Old Jan 21, 2015 | 10:34 PM
Oncomingstorm22's Avatar
I have a 95 z28 that was just freshly rebuilt. It's had a problem since I got it back around Christmas. I'm on my second new battery (the first had a dead cell). After I installed the new battery it ran fine and I didn't drive it the next day. The day after that I go to start it and its stone cold dead. I charge it and it turns over no problem. I remove the positive cable and it keeps running. Then I turn it off and back on and it just starts and dies. If I hold the key I can get it to stay on but the voltmeter keeps jumping around and then it will die. I've replaced the starter, ignition cylinder, alternator, opti, plugs, and most everything under the hood. Also the template keys that came with the cylinder work despite not having a chip? One of the wires on my old ignition was cut and my security light has been on since I bought it in 2011. Idk if any of that is relevant, just being thorough. I've spent every penny I have on this rebuild. I've been without a car for a year.
Old Jan 22, 2015 | 06:55 AM
Re: Car starts then dies immediately
If a component of the PASS-Key system fails while the engine is running, the "SECURITY" light comes on full time, and the security system is bypassed. The engine will start without the proper resistor. Alternatively, someone could have inserted a resistor in the circuit to bypass that part of the system.
Here's a guide to the security system (courtesy of Shoebox - bookmark his site):
4th Gen LT1 F-Body Tech-PassKey/VATS
http://shbox.com/1/vats_bypass.jpg
With the system bypassed, it isn't likely that is the problem causing it to stall, but it would be a good idea to try and troubleshoot the security system to straighten it out.
Sounds like you may have some sort of parasitic load draining the battery when the key is off. That can be traced by putting a mult-meter set to DC amps in series with the battery cable, with the key in the off position (DO NOT TRY AND START THE ENGINE - you will toast the multi-meter). Any current flow more than a few 1/10ths of an amp will need to be tracked down.
The stalling is probably not related to the battery running down overnight. Possible reasons for the stall:
-weak fuel pressure (check pressure)
-EGR valve stuck open
-faulty MAF sensor (unplug MAF sensor, putting PCM into speed-density
-faulty coolant temp sensor in water pump housing (see test procedure below)
4th Gen LT1 F-body Tech Articles
Need to check it for codes.
https://www.camaroz28.com/forums/com...95-lt1-874306/
Old Jan 22, 2015 | 04:30 PM
I forgot to mention that the coolant temp sensor isn't hooked up, because they gave me the wrong one (on block) and when it was running it smelled heavily of exhaust in the cab.
Old Jan 22, 2015 | 04:52 PM
GaryDoug's Avatar
Prominent Member
Which sensor is not hooked up, the one on the front of the water pump or the one in the driver side head? There is none in the block. The one in the head only affects the gauge.
Old Jan 22, 2015 | 07:15 PM
That's what I meant, in the head.
97SSdude
Dec 31, 2014 07:43 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
