car pulling 2 directions....
THe title gives about the jist of it.
I have a new problem now. Not sure if it's suspension or the rearend. I recently replaced the PHB w/ an adjustable unit. I measured it w/ the old one and 'eyed' it center for now.
THis just started happening about two days ago....When I gas it, past half throttle, it pulls to the left. When I lay off and decelerate right after, it pulls harder than usual to the right. (my alignment is slightly off)
WOuld this be the rearend only getting traction to one wheel??
Re: car pulling 2 directions....
I went off the road when I first got the car about 3.5 years ago, never got the front end fixed, (wasn't bad) but I had it re-aligned when I had new shoes put on.....about a year and a half ago. It allways steered a hair off center to the right but never this bad.
I went to have my wheels fitted (wrong offset), and they put the right side back on and it was doing it since.....
I'll check at lunch... Chinese Buffet today!
I just thought of something.....subframe twist?
EDIT:...Tires are wearing/worn Normally.
The rear's look a little low on tread, tho....
sleeperZ96BT
Jun 5, 2005 09:33 PM
