Car leaking, need help
The car is leaking a LOT of fluid. It’s pink and watery in texture, its dark, so I can’t see where it’s coming from, but I would assume its transmission fluid. I just wanted to verify with you guys because I’ve never seen transmission fluid, as embarrassing as that is
Also, can I drive on it without damage as I have to get to work in the morning, and the dealer usually takes a week to get into ...
And what the hell would cause this anyway? And do you know how much fluid it holds?
Thanks!!
Thanks!!
I agree. Before you drive it, check your tranny and PS fluid. If you can't tell where its coming from, put a big piece of cardboard under your car after you drive it, it will be more evident than asphalt.
