Car idle's really low when I turn the AC on
Old Jun 8, 2008 | 09:55 PM
97 RedSS's Avatar
Would this be a programming issue or do I just need to open up my TB blades some more with the throttle stop screw?
It idles perfect when the AC is off (800-850rpms) around 1k shows on the tach.
When the AC is turned ON the idle drops to 600 or so and stays there everytime I stop the car.
Cody
Old Jun 8, 2008 | 10:03 PM
windsma's Avatar
usually in FI cars there is a ac sensor that tells the ECM to idle up for the extra load
Old Jun 8, 2008 | 11:43 PM
Exactly... the PCM knows when the A/C is running, and opens the IAC valve more to hold the idle at spec. It should not slow down when the A/C is on. Since you appear to have a scanner that allows you ro read the RPM from the PCM, use it to watch what happens to the IAC counts when you turn the A/C on. If the counts increase, but the idle does not, you know there's a problem with the IAC valve.
Old Jun 8, 2008 | 11:45 PM
97 RedSS's Avatar
Thanks guys. I'll do some troubleshooting this week..
Cody
CARiD
Dec 26, 2014 04:20 AM
CaRParts102
Dec 6, 2014 08:45 AM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
Vokabulis
Jul 25, 2002 05:46 AM
