A/C Servicing/Recharging
Originally posted by HBHRacing
yes. too much oil can case problems. I would jus stick to regualr 12 ounce cans of 134A and be safe. but 3 ounces "should" be ok. but no more
yeah. the 3 pounces shold be ok. just use nothing but 134a after that first can
sounds like either you broke the mainfold line on the back of the compresor or maybe a high pressure valve. you need to get back there and see whats up. if it;s that bad of a leak you should be able to see it b just adding freon with teh car off...
what ever it is it;s a bad bad leak and need to start there. usualy a bad compressor will not leak out that fast so I doubt thats it but it could still be bad but you need to track down the leak first..
if it;s not leaking out now then the hole is on the discharge (high) side.... the compressor will not function correctly if there is an open in the system so start there.
have a buddy help you. jack the car up. get to where you can see the hoses at the back of teh compressor. then have him turn it on. find and fix the leak. then we can go from there
your just gonna have to see where it;s leaking from. could be the hose assembly.. could be the comprssor, could be the blow off valve etc etc etc. you will just have to run it and see..
step 1. find the leak
step 2 empy the freon
step 3. fix the leak
step 4 try it again and see what happnes
i went back out there and hooked up the can of freon again and the psi wa sstill 45 psi after i let some pressure out. i started the car. a/c compressor wasnt turning and it was blowing woamr ait. thatss fine. i started to just add a litttle bit to it and pressur rose from 45 to about 50 psi. clutch kicked on and it l had my eye on it the whole time. i stopped letting freon in by closing the tap valve. clutch kicke d on and it spun about 3 times around the compressor looked loose and rattled and then after the 3rd rotatino it locked and got in the bind. made the noise i have been talking about. i quickly shut off the a/c and released the prssure back to 45 psi. looked at my passenger side exhaust manfiold and i could see wet spots of i think where the freon sprayed. looked down by the rear of the compressor and i could see more wet spots on where the crossmember bolts onto the car. so it ihnk it is spraying from the back of the compressor thus the white vapor and the smell. i think i remember smelling the sme thing b4 my a/c went out that day this past winter. then it just quit. a/c compressor never used to do this (clutch rattling looking loose while spinning and then locking itself in a bind). neever did this b4 as the a/c worked fine. i do believe there is the leak in the back of the ocmpressor. havnet jacked it up to see yet but i will try to today. if i fix the leak somehow will it fix the clutch on the compressor from lockin gup in that bind it does? its kind of like since it leaks out theres not enough pressure held for the compressor's clutch to spin freely and therefore spins some then locks itself in a bind and makes this noise like letting air out or freon out. i dont want this to be costly but it ihink it is oging to be and a paint in the ***. i might take it to someone and have them check it out and see. i can live without a/c i have for so long my cars never had it b4 but it just bothers me that it was workign fine one day an djust quit the next. this is going to be my car for a long time and i wanted to make sure everything works fine just like the a/c. plus when it rains its hell and it has rained here lately and been hot and humid. sometimes i cant stand the heat in the car. it sucks really bad.
when the ac is off and a full chagre is in the low side will read up to around 120 PSI.. thats normal. when the compressor comes on it will lower to about 45. so don;t worry if you see mnore then 45 when the ac is off. thats fine
