A/C diagnostics
Old Aug 22, 2005 | 10:09 AM
weinerschizel's Avatar
A/C diagnostics
Is there a good way to test the seals on an A/C system with out wasting all kinds of freon?
Also I discovered the pipe that runs into the back of my compressor leaks. I'm not sure if it's bent or just has some bad seals. What do you guys recommend for fixing an issue such as this.
Thanks!
Old Aug 23, 2005 | 10:24 AM
HBHRacing's Avatar
Re: A/C diagnostics
Without freon in the system you can't check for leaks.
If the hose at the back of the compressor leaks then you need to replace it. It's called the manifold hose assembly or sucktion/discharge assembly.
Old Aug 23, 2005 | 10:38 AM
CheshireCat's Avatar
Re: A/C diagnostics
You can test for leaks by putting a vaccum on the system... If it doesn't hold, then you know you have a leak... It won't tell you where the leak is though... The best way to find a leak is to use a UV detection system...
If you don't have the right tools and products, you're probably better off taking it to a qualified AC tech shop...
Good luck...
Old Sep 9, 2005 | 09:56 PM
Re: A/C diagnostics
What is the easiest way to change that manifold hose assembly or sucktion/discharge assembly? I would like to do it on my own. However, that is how we broke the last one.
magman
Apr 15, 2016 03:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
MikeWhitener
Aug 2, 2015 06:17 PM
