bubbles in paint on roof. help
Old Aug 7, 2006 | 11:37 AM
jacvily@sbcglobal.ne's Avatar
i noticed yesterday that i have bubbles in the paint on my roof. its a hardtop. i dont think its rust as i dont think the roof is metal. any help would be appreciated.
Old Aug 7, 2006 | 11:48 AM
shock6906's Avatar
Re: bubbles in paint on roof. help
Depending on what year the car is, this is a fairly common problem and has been discussed a few times before. If you do a search you can find more info. A quick rundown on the problem is that they changed the adhesive they use to glue the roof to the car (i forget what year) and it has a bad interaction with the panel and the paint, causing it to bubble.
Old Aug 7, 2006 | 11:18 PM
Lt1t56's Avatar
I sold a 95 Z28 2 years ago that I had owned for 3 years and the clear coat was starting to come off on the front drivers corner of the roof.
The car I now have is doing the same and getting progressively worse with Texas heat.
Both are hard top cars.
Iam guessing its a common problem.
Old Aug 7, 2006 | 11:52 PM
shock6906's Avatar
It wasn't an issue with the clearcoat itself, it's all the layers of paint and clear lifting as a solid sheet up off of the roof. It also wasn't an issue on any of the LT-1 style cars, and I believe it only started in 2000, although I may be wrong. Like I said, do a search to find exactly what's up.
Old Aug 8, 2006 | 11:30 AM
JaysGone's Avatar
I had the roof replaced on my 02 by Chevy. Its a known defect. Now as to if they will fix this on a used or xteen year old car I doubt it. Repainting will not cure the problem it will bubble again someplace else. It is a reaction between the addhesive and the paint in the roof panel. Good luck
Old Aug 8, 2006 | 11:05 PM
rooster99ss's Avatar
mine's doing the same thing. I called around myself looking for a recall, dealership won't do anything about it. Would like to know a good way to fix it and not have it come back...
Old Aug 8, 2006 | 11:17 PM
shock6906's Avatar
I believe the only way you can fix it without any problems coming back is to have the roof panel removed from the car and have a different kind of adhesive used to apply it back.
Old Aug 8, 2006 | 11:29 PM
Skull Leader's Avatar
Angry Re: bubbles in paint on roof. help
After 9 years, mine started peeling from the back, and now the front.
Old Oct 11, 2006 | 02:23 PM
frey51's Avatar
I am having the same problem on my 02, I just noticed it. I remember a document that was posted either here or ls1tech that would most likely get your roof replaced from the dealer. I need to get some help on this one too. Any suggestions.
Fry
Old Oct 11, 2006 | 02:38 PM
landshark's Avatar
Just got mine back from the local dealership having this very problem fixed on my '01 SS Hardtop. The roof had at least 100 leaking blisters that had formed. Anytime the car was in direct sunlight more would pop up. It took me 3 years, 3 dealerships, and countless calls to GM to finally get this fixed under there "paint warranty". Good luck, persistance is important in this matter, never take no for an answer.
Old Oct 11, 2006 | 03:05 PM
JoeMack's Avatar
You might want to read these posts. It has a link to the TSB.
http://www.ls1tech.com/forums/showthread.php?t=497097
Old Oct 11, 2006 | 03:14 PM
frey51's Avatar
Thanks for the link Joe, thats the what I was looking for.
Landshark, do you have any advice for this regarding the 'Paint Warranty'. Like who should I talk to at the dealership other than the service tech who answer the phone or takes you at the counter.
I just got off the phone with the dealer and they told me $1200 to fix it. Im sure if I have the correct information I may be able to get it done.
Old Oct 11, 2006 | 03:22 PM
GhostZ28's Avatar
dude frey, you have GOT to shorten your sig to 5 lines max
Old Oct 11, 2006 | 03:41 PM
frey51's Avatar
nah, its good the way it is Honestly I havnt touched it in months, It is a bit long though.
Old Oct 11, 2006 | 04:31 PM
camaro777tom's Avatar
Time to get rid of it and do a T-Top conversion!
