Both power mirrors will not go up/down what do I need to fix?
Old Dec 19, 2004 | 12:01 PM
2QUIK6's Avatar
On my '95 TA both passenger and driver outside power mirrors will not go up and down. They move left and right just fine. I took the switch out and verified that it is working properly using Shoebox's switch wiring diagram.
So now is there a separate motor that controls up and down or is that actually behind each mirror?? I hear the motor running when moving rt/left right behind each mirror so if it was a motor I'm not sure why both suides would go out at the same time....
Old Dec 19, 2004 | 09:54 PM
Compstall's Avatar
Re: Both power mirrors will not go up/down what do I need to fix?
I would still look at the switch. I find it highly ironic that BOTH sides wouldn't work at the same time when using one switch.
Old Dec 19, 2004 | 11:15 PM
2QUIK6's Avatar
Well thats what I thought too, so this afternoon I took the switch out of my '99 and tried it, but it made no difference.
So are the motors behind the mirror? If so, then I'll take that apart and start poking around there with the volt/amp meter to see if its getting power to it when the botton is depressed.
Old Dec 20, 2004 | 01:51 AM
Compstall's Avatar
Look at the schematic and see if there's any other common point for both sides between the switch and the motors.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
guruerror
Dec 12, 2020 06:32 PM
siguy
Nov 27, 2014 10:07 AM
XtremeLt1
Sep 13, 2002 08:50 PM
