Which bolts to remove on starter?
Old Jul 23, 2006 | 10:16 AM
b-stevens's Avatar
I'm not very good at cars obviously, but as per Shoebox's picture, am I removing the two bolts on the top left and wires that you see in the picture here? http://shbox.com/1/starter.jpg
or am I removing numbers 16 here? http://shbox.com/1/starter_gear.jpg
I would assume both?
And how the hell are you guys getting to these? Did you guys remove your y-pipes to get a little more room?
Old Jul 23, 2006 | 11:09 AM
s10er8's Avatar
Re: Which bolts to remove on starter?
numbers 16 that come straight up from the bottom
Old Jul 23, 2006 | 11:18 AM
b-stevens's Avatar
those are the ones that are seemingly impossible to remove... header heat + rust =
Been spraying PB blaster on them off and on and giving them a try every so often but no luck so far
Old Jul 23, 2006 | 01:54 PM
b-stevens's Avatar
Got the bolts out, came out pretty easy with a longer wrench, but I either have to take the y-pipe off of my mac mids, or struggle my *** off getting the wires off since there's so little room to work.
The problem with the first option is that on two of the bolts from the y-pipe/headers I can only manage the slightest turn of wrench (not even enough to take it off and put it back on to get another slight turn.
I guess I'm going to make a trip to the hardware store and buy some more tools.
Old Jul 23, 2006 | 02:36 PM
s10er8's Avatar
yeah it won't be easy but you shouldn't have to drop the exhaust, that could be a whole other set of issues in itself.
Old Jul 23, 2006 | 03:22 PM
2000GTP's Avatar
I think I had to use a breaker bar on those two bolts, they were really in there and did not want to budge very easily.
Old Jul 23, 2006 | 03:41 PM
Mustang Crusher's Avatar
I just changed mine out. And it was easy..but it has a trick to removing it easy. you got to play with it to figure out how to take it out. You got to turn it like twice around while pulling it out to clear all the parts around it. But yes, just the 2 bolts hold it in place. Trust me, after you figure out the rotation that you must do to take it out, it's all down hill from there. Don't forget to puit back the spacers that it has, you need those.
Old Jul 23, 2006 | 03:47 PM
94Z28WP's Avatar
I've always unbolted the starter wiring first using a long extension and getting to it in the front over the motor mount... Then I unbolt the two starter mount bolts... On mine, I have to flip the starter so the nose is pointing straight up and I pull it down backwards.
Old Jul 23, 2006 | 04:35 PM
b-stevens's Avatar
What size nuts are holding the wires in place? I kind of gave up for awhile, seeing as how I'm not driving it tomorrow anyways.
Maybe i'll just put it back in place and try to reach over the crossmember to unscrew those.
Thats been the hardest thing to figure out so far since there's so little play room.
Old Jul 23, 2006 | 04:42 PM
s10er8's Avatar
on the wires they are something like 1/2" and 5/16" maybe I cant remember
Old Jul 23, 2006 | 10:28 PM
b-stevens's Avatar
I'm definitely attempting this in the after work tomorrow, I just have to locate the rest of my sockets that fit on a 1/2" wrench, since I have a long enough extension to go over the crossmember
Old Jul 24, 2006 | 10:48 PM
Compstall's Avatar
+1. I do it this way every time. Took mine out twice in the last week.
Old Jul 25, 2006 | 01:01 AM
b-stevens's Avatar
I ended up just dropping the y-pipe anyways because I wanted to have a look around the flanges anyways to see if there was evidence of a leak. I can't see evidence but boy were the harder to get bolts loose. Hopefully when I toss it back on there it stays tight.
Oh and p.s. I had my starter tested and it was very weak because I have an oil leak somewhere (maybe even two places) that caused oil to get in the starter, which dulls the conductivity of the starter? (This is what the guy at the autoparts store told me) So can I just take apart the starter and clean it out? or is it necessary to replace it?
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
thenewkid
Nov 18, 2014 12:57 PM
