Blinkers won't flash. Just stay solid.
Old Aug 13, 2011 | 01:59 AM
SSinister11x's Avatar
Hello. I just noticed my blinkers won't blink. They stay solid and I don't know why. I just installed a new CD player and door speakers. ? Doubt that has anything to do with it but I don't know. Any help would be awesome.
Old Aug 13, 2011 | 02:22 AM
rv93's Avatar
Re: Blinkers won't flash. Just stay solid.
you either have a blown light bulb, or a bad flasher. most likely a bulb, so check those. also check the sockets for a good connection
Old Aug 13, 2011 | 04:49 AM
Thank you, I'll check em out. Wouldn't that cause a fast blinker though?
Old Aug 13, 2011 | 07:58 AM
jonesz28's Avatar
I had this happen with just one side, removed the tailight a few inches and checked all bulbs and they were all working. I wiggled all the wiring and just put it back in and it ended up working after that. I imagine it was just a wiring/connection issue but its working fine now. Prob doesnt help much but is my experience with it.
Old Aug 13, 2011 | 08:08 AM
No. Just the opposite.
Old Aug 13, 2011 | 10:26 AM
Would having LEDs cause this problem? Im not running resistors with mine.
Old Aug 13, 2011 | 02:45 PM
It could. The stock flasher needs the resistance of normal bulbs to work. You might try using an electronic flasher.
Old Aug 13, 2011 | 02:50 PM
rv93's Avatar
ah, probably should have mentioned the LED lights. yes, even just replacing the front or back with LEDs will cause it to stop flashing. however, using an electronic flasher will fix it. ive been there.
Nayr
Mar 3, 2023 08:34 PM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
