Big Cam w/Stock Converter
Old Feb 8, 2005 | 10:57 AM
NVRLATE's Avatar
Anyone running a big cam with their stock converter. I was wanting to do a cam swap but I didn't want to do the converter at the same time. What problems or driveability issues will I run into if any? Can I do damage to the trans or motor?
By big cam I mean CC306 or larger.
Thanks,
Dave
Old Feb 8, 2005 | 12:54 PM
Z28SORR's Avatar
Re: Big Cam w/Stock Converter
Thanks,
Dave
The normal problem with this is, the cam idle has to be fairly high. Often high enough that the torque converter is "ingaged" when the car is stopped, causing the engine to stall. This requires even high idle to over came, which then makes stopping the car difficult.
Do them together or get the converter first.
Old Feb 10, 2005 | 02:16 AM
jeremyferguson's Avatar
I agree 100%, I wanted to do both but wasn't sure which to do first....I decided to go with stall and trans-go "shift kit", and was amazed by the differnence. Felt like a whole new car and before any suspension work, and just nitto's I was cutting 1.75 60' times NA. Car felt like a slingshot at the track. On the street I can mash it at a 15mph roll and burn the nitto's.
Old Feb 11, 2005 | 07:11 AM
qukz28's Avatar
I have the Lt4 hotcam kit in my lt2 car. Running a stock converter and makes the car difficult to stop. Buy a converter first!!!
Old Feb 11, 2005 | 10:18 PM
NVRLATE's Avatar
Thanks for the advice. Now I gotta figure out what size converter I want. 2800 or 3200?
Old Feb 12, 2005 | 03:11 PM
I think you would regret getting anything smaller than a 3200. You might be happy with a 2800, but if you knew how much better a 3200+ felt and performed you'll wish you went with bigger.
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
ChrisFrez
Feb 15, 2015 07:49 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
