Battery Issue? Car doesnt start, Help!!
Old Feb 10, 2007 | 07:39 PM
lovemyblackz28's Avatar
I get into my car tonight and try starting up the car. I just hear this very fast clicking noise. What does that mean? I drove my car 2 days ago without any problems. Do I need a new battery? The headlights were working. Battery is maybe 2 years old.
Old Feb 10, 2007 | 10:15 PM
2000GTP's Avatar
Could be a weak battery that finally went bad. You could take it to a parts store and have them load test it for you and go from there.
Old Feb 11, 2007 | 08:50 AM
oneslowz28's Avatar
chech the connections for corrosion then if there tight /not corroded and it wont start take it to a parts house and have it load tested. then if its bad buy a better bat.
Old Feb 11, 2007 | 08:54 AM
Bayer-Z28's Avatar
Battery s**t the bed on ya. Low voltage would cause the clicking. Unless you left something on, it sounds like it's not holding a charge.
Old Feb 11, 2007 | 09:06 AM
jonm38's Avatar
One thing that would cause the battery to dead, is if you have any shorts or something that is drawing power when your key is off. There are systems on a Camaro that would draw power that are always on, like the air bags!
Old Feb 11, 2007 | 10:40 AM
Sounds like im gonna have to get a new battery. It has nothing to do with the starter does it? like i said, i drove the car 2 days ago and the voltage gauge looked fine to me.
Old Feb 11, 2007 | 10:51 AM
elevario's Avatar
I know this doesn't sound like fun but you should get your alternator checked as well. Your battery could be fine but the alternator could just be failing at recharging.
I would say, get your battery checked out at a AutoZone/Checker type store. If they say it's fine, then you may need to get the alternator checked out. Good luck man! I wish you the best.
Old Feb 11, 2007 | 11:38 AM
2001NBMZ28's Avatar
Most batteries have a free 3 year replacement warranty, then prorated after that.
Old Feb 11, 2007 | 12:13 PM
2000GTP's Avatar
There are many cases that can lead to a no-start, a bad starter being one of them. However, I would check the battery first, which is the easiest starting point and one of the more common culprits.
Old Feb 13, 2007 | 10:59 AM
Threw in a new battery and its working fine. The battery was the culprit. Thanx for the help!!
bfmv13trivium
Jan 14, 2015 09:57 AM
Britbilly
Jan 7, 2015 08:49 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Dave19yz28
Jan 26, 2003 01:45 PM
