Bad vibration at high speed
Old Apr 19, 2005 | 06:03 PM
bg552's Avatar
Took my Z on the expressway for the first time in quite a while. I noticed that once it gets up to about 90-100, i get some harsh vibration from the car. It is accompanied by a nice loud humming/buzzing sound. Both of these symptoms get worse as the speed increases. What the hell is causing this?
Old Apr 19, 2005 | 06:19 PM
IRONFIST's Avatar
Re: Bad vibration at high speed
Alighnment? Bad wheel bearing?
Old Apr 19, 2005 | 06:27 PM
hatredizm's Avatar
Well a vibration can travel from anywhere on a car. U-joint, harmonic balancer, tires and so on.
Old Apr 19, 2005 | 07:34 PM
99andMine's Avatar
Start with the simplest and cheapest, get your tires balanced and rotated. That doesnt work take a look at your bearings and so on and so on. Let us know.
Old Apr 19, 2005 | 07:35 PM
bg552's Avatar
Picking up a new wheel from the shop later this week, so ill have it done then. Thanks for the info guys.
Old Apr 19, 2005 | 07:51 PM
Bayer-Z28's Avatar
Slightly out of ballance wheel will do that. won't notice it around town but over 70, yeah...
Old Apr 19, 2005 | 10:50 PM
Mike94ZLT1's Avatar
Have you all forgotten about "Vibeshaft"????
Old Apr 19, 2005 | 11:38 PM
Metlhed54's Avatar
i can't believe it took someone that many posts to mention the infamous driveshaft vibration. i have it, i hate it, and i bet thats what ur problem is.
Old Apr 21, 2005 | 10:08 PM
bg552's Avatar
checked it again today and it seems that at around 70 if i go WOT it will happen, and when i let off it will stop until i get to higher speeds...sounds more serious than an out of balance wheel...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
karnykamaro
Feb 2, 2015 01:37 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
mattszm6
Dec 14, 2014 07:09 AM
