Automatic Headlights?
Old Feb 5, 2005 | 06:13 PM
BurningIce73's Avatar
Hey guys, I believe most stock camaros come w/ auto headlights?....is there and easy way to get it off that and put it on a switch?
Old Feb 5, 2005 | 06:32 PM
camaro 22's Avatar
Re: Automatic Headlights?
You can cut the wire to your sensor "eye" that's on top of your dash near the windshield. Then just use your factory switch to turn them on and off.
Old Feb 5, 2005 | 06:34 PM
Z28Nut's Avatar
camaro 22 -- do you know if this would work on a 2000 Blazer? I don't have auto headlights on my 94Z but the Blazer has 'em and they suck.
Old Feb 5, 2005 | 10:54 PM
Lt1t56's Avatar
Here is a link on disabling auto headlights
http://www.fasidemedia.com/personal/...eautolamps.htm
Old Feb 5, 2005 | 10:58 PM
Ron78Z&01SS's Avatar
When I got rid of it on my SS I pulled the center defrost grill up so I could get to the bottom of the light sensor.
Disconnect the plug from the bottom of the sensor and use a cut down paper clip or piece of safety wire to complete the circuit on the plug.
Wrap some electrical tape around the plug so that the wire doesn't end up grounding out against anything.
Less than 15 minutes and you're done.
Not sure were camaro 22 heard about just cutting the wire to the sensor unless the set-up on '97's are different though.
Old Feb 5, 2005 | 11:04 PM
Z28Nut's Avatar
I love you, man! Thanks for the link - I was having no luck with searches on the ZR2 board I am on.
WobblySausage
Oct 7, 2015 10:09 AM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
drt
Sep 27, 2015 04:39 PM
Greg88
Sep 20, 2015 07:14 PM
