Auto shifter question
Old Jan 22, 2008 | 09:37 PM
car-15's Avatar
I have a 1995 Z28. It has the auto trans. My shifter label is as follows:
P
R
N
OD
D
My buddies 1995 Z28 convertable has the following (I think, I could be wrong):
P
R
N
OD
D
What gives? Mine has the space for me to shift into the "1" position but the tranny won't go back past 2
Make any sense? Hope so!!
Old Jan 22, 2008 | 09:52 PM
There are probably hundreds of threads about this. You can search to find out specifics.
Bottom line is cut off the block that keeps the shifter from going all the way back and you will be able to pull it into 1st gear.
Old Jan 23, 2008 | 10:37 AM
car-15's Avatar
I tried searching and didn't find anything. could you point me in the right direction?
Thanks!!
Old Jan 23, 2008 | 10:45 AM
Green96Z's Avatar
https://www.camaroz28.com/forums/sho...lectable+first
Old Jan 23, 2008 | 12:57 PM
car-15's Avatar
Thanks guys, I already sawed it out! I just wasn't using the right words to search!
Too bad I have 2:73 gears, I was hoping I didn't
Old Jan 23, 2008 | 01:47 PM
The gears are good for gas mileage, if you do a lot of highway driving.
Old Jan 23, 2008 | 02:13 PM
car-15's Avatar
Yeah, I have owned several Mustangs with the 2:73 and they were good on the highway. Unfortunately I purchased the Z as my weekend/toy.
I guess I'll have to look into adding new gears in the future.
What, if anything has to be done to the trans to make the MPH's show up right if I swap gears?
Old Jan 23, 2008 | 03:23 PM
You will need a reprogram of the PCM to correct for new gears.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Moshbmx1
Feb 17, 2015 10:51 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Jan 11, 2015 03:47 PM
tds1213
Nov 27, 2014 12:55 PM
