Anyone Else Give Up Changing Valve Springs With Heads In Car?
I am no wimp but this has got to be one of the hardest things you can even attempt. I worked for 1 hour learning the tricks to doing it on the easiest to get to cylinder then gave up when I realized it would be nearly impossible to get to the ones in the back with the other, even harder to use valve spring compressor tool (the twist down claw type). What I found to be nearly impossible was getting the locks to fit. Getting just the first one down without the valve falling in a little was torture. Wiggling the compressor around after getting the first one in seemed to help to get the second one in. I bow my head to anyone who can do this in a reasonable amount of time.
I'm no quiter so I went out and tried the intake side on the easy cylinder and it had another issue, the locks wouldn't let go. I had to really rap it with a mallet/large socket to get it loose. This brings up the next issue which is if the back 7 and 8 valve locks don't let go how the heck are you supposed to whack them? Anyone trying this for the first time I'd say do the easy cylinder first then go straight for the back two and you may find you can't get them off. Once again I throw in the towel
This was just more of a warning for those new to it. There are few, if any, warnings about the difficulty of doing this. I wonder how many people bought all the parts then found out the hard and expensive way this can be impossible to do with the heads on?
Hal
Hal
Shoebox, it looks like you even took all the rockers off first. I can see how that would help the view to the back. I admit I might press on but I don't have a garage right now (converted to room/storage) and it's only getting hotter outside.
I may just put a 50 shot on instead. It doesn't cost that much more than doing a full swap rr/tools/rods/springs/other. With a remote bottle opener it would be there when I need more
Hal
Hal
Hal
That Crane tool does look like it makes it easy. I wish they didn't charge so much for such a simple thing. Oddly, I can't find a deal on it anywhere. But, I could get one and put it on ebay and not lose much.
Hal
Hal
