Antenna mast and motor questions
Old Jun 13, 2005 | 08:19 AM
BacardiTA's Avatar
I've searched around (including this site) and can't get a good idea of a few things regarding the power antenna on my 2000 TA. It makes noise when I turn the radio on, but the antenna stays all the way in the up position. I can't push it down, even if I disconnect the power to it. It has a "springy" kinda feel to it.
I want to troubleshoot it, but I'm not sure how it works. What actually connects the antenna to the motor and how does it work? I've heard of a cable of some sort, but not sure if that is on the motor or what. Also heard of a rebuild kit... think that'd take care of it? What all does the repair kit replace? I didn't want to just go buy a whole unit replacement for $90, or just a motor or mast individually when I don't even know what needs to be replaced.
Anyone with experience on this that can help out I'd greatly appreciate it.
Old Jun 13, 2005 | 11:11 AM
moparman's Avatar
Re: Antenna mast and motor questions
AFAIK, they are unrepairable. No cable available. You'll have to get a new one, or put up with what you have now.
Old Jun 13, 2005 | 12:00 PM
1 Nasty Bird's Avatar
The motor and mast assembly is sold seperatly as far as ive seen. My parts guy that is supposed to be 10% over dealers cost quoted me just over 30 dollars for a mast kit and i beleive the motor was around 90. The way it works is theres a fairly thick plastic line thats inside the antanea that opushes it up and pulls it down. It winds up inside the motor assembly. SOunds like you may hvae a break in the line where it attaches to the motor.
Old Jun 13, 2005 | 01:32 PM
BacardiTA's Avatar
If the cable is broke, would I need a new mast or a new motor assembly? No such thing as a rebuild kit?
Thanks for the replies!
Old Jun 13, 2005 | 02:09 PM
moparman's Avatar
When I replaced my power antenna, the whole thing was about $80 from Dal. That's mast and motor. Yes, there is a cable, but you can't just buy it. Some cars you can, but not 4th gen.
Old Jun 13, 2005 | 11:03 PM
Lt1t56's Avatar
Sounds like the mast is broken inside the motor, on my 95 T/A the mast part # 10256439 according to the dealer, it might be different on your 2000 model.
ChrisFrez
Jan 18, 2015 08:05 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
97_396_WS6
Aug 4, 2002 10:23 PM
Red97LT1
Aug 4, 2002 08:01 PM
$hawn
Aug 3, 2002 04:59 AM
