Another AC thread w/pics
Old Apr 10, 2010 | 06:41 PM
z28_4life's Avatar
I took my car in to have the ac recharged and coolant flushed. Well, they flushed the coolant but apparently I have no voltage going to the ac condenser. I told them just to flush the coolant and I would look into the voltage issue. I was able to locate this sensor which was unplugged (it has a box that runs inline with the wire). Any idea of this could relate to the ac. Either way I need to plug it back in and I couldn't find the location of where it went. I'm sure there's some guru's on here that have had the complete dash out and all the wiring harness unplugged...
[IMG][/IMG]
Old Apr 10, 2010 | 07:40 PM
Wire blue, black and grey? That is the evaporator core temp sensor. It sticks in the evaporator under the dash to measure it's temp and send it to the computer.
Old Apr 10, 2010 | 07:50 PM
z28_4life's Avatar
thx shoebox...I'll plug it in and hopefully I'll have some nice cool air for this brutal summer coming up.
Old Apr 10, 2010 | 08:12 PM
z28_4life's Avatar
Yes, the wires coming out are blue, black, and gray. Do I need to remove the black box containing the heater core to gain access to the evaporator? Do I need to remove the blend air door housing to gain access to the evaporator insertion point. It says in the chiltons that I have to cut a hole in the plastic to gain entry and then epoxy once done but I'd rather remove the hole thing if need be to avoid hacking stuff up. I don't want to keep ripping stuff out until I'm sure exactly what I'm looking for though. thx.
Old Apr 10, 2010 | 09:00 PM
z28_4life's Avatar
Boom shockalocka https://www.camaroz28.com/forums/sho...re+temp+sensor I just wish it had a picture of the insertion point on the heater core frame he is referring to. I can clearly see where the box goes.
n2oblkz
Oct 22, 2015 02:31 PM
Double aught
Oct 2, 2015 11:29 PM
Formula Steve
Sep 19, 2015 08:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
cmsmith
Aug 17, 2015 06:50 PM
