Alternators for LT1 cars
Old Jun 18, 2008 | 10:09 AM
BLUESMOKE's Avatar
Quick question.. i have a 94 z28, would an alternator from a 96 WS6 fit my car or were there differences in model years/pontiac-chevy?
thanks
Old Jun 18, 2008 | 01:32 PM
There were some changes in 1994 so you need to know which alternator you have. You could have a 124 amp or 140 amp. Late 94-97 use the 140 amp and they should all be the same for the f-body cars (Chevy or Pontiac). The earlier 124 amp alts would be likewise.
Identifying them:
A 124 amp alt will have a metal fan and a bolt that secures the + battery cable to the back.
A 140 amp alt will have a plastic fan and a stud/nut that secures the + battery cable to the back.
With all that said, if you have the 124 amp alt, you should be able to bolt in the 140 amp alt for an easy upgrade. I don't know if there might be a slight belt length difference if you did that (pulleys may/may not be the same size), but it would not be hard to remedy with another belt.
Old Jun 18, 2008 | 02:42 PM
BLUESMOKE's Avatar
Thanks for the reply!
So what your saying is the worst thing that could happen if i tried to put on an alternator off a 96 ws6 is that i may need a different length belt?
Oh, i should have mentioned, my alternator is a police package (black) alternator...is it fair to say it's a 140amp?
Identifying them:
Old Jun 18, 2008 | 03:16 PM
Yeah, it should work regardless of what you have (with maybe the belt difference).
The police package had the same alternator as the normal LT1 equipped cars.
Old Jun 18, 2008 | 07:46 PM
jhthornley's Avatar
shoebox,
when you say "plastic fan", what exactly are you referring to? I have the "stud/nut" for the positive battery cable, but don't remember anything plastic..
Just trying to learn all I can.
Thx
JT
Old Jun 19, 2008 | 06:14 AM
Craddock's Avatar
The fan that is on the front of the alternator is plastic. It's the part just in front of the alternator if you're looking at it from the front of the car.
nophix
Nov 30, 2014 10:26 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
