Air conditioning problem...
Old Sep 27, 2008 | 12:20 PM
LSWHO's Avatar
So this last week my car's been making weird sounds while the A/C was on. It would intermittently make these pressure release sounds. It seemed to come from the passenger side then the middle vents. Just drove the car to a lift so I could pull the o2 sensor and it's no blowing hot air.
Is this normal for when it needs recharge? Is there a strange leak all of a sudden?
It may have been making the "sounds" for more than a week, but normally my music drowns it out pretty easily. It's just this week I've been afraid I blew my motor so I was listening for knock and that's when I started to notice it.
Any insight?
Old Sep 30, 2008 | 12:36 AM
LSWHO's Avatar
I see...
Old Sep 30, 2008 | 01:55 PM
2001NBMZ28's Avatar
Don't know about the sounds, usually when the charge gets low enough the pressure switch will just keep the compressor from running, and then blow hot air. I'd pick up a recharge kit with a gauge and 134a with dye in it if you suspect a leak. If you have a guage see what the static (car off) system presssure is.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
