Air Conditioning Problem...
Old Sep 28, 2005 | 03:15 PM
RallyRed701/2's Avatar
My AC... like most's... doesn't work. My question is: what is the cheapest/easiest way to figure out what part of the system is not working. I know about putting the die in the lines, but im not sure that its leaking as much as it just doesn't work. I believe there's something busted and i have no idea how to figure out what it is... (compressor, evaporator, condensor...etc...)??? any ideas?
Old Sep 28, 2005 | 03:49 PM
1986camaroz28's Avatar
Re: Air Conditioning Problem...
Start With The Compressor, Does It Come On When You Turn The A/c On? If Not (with The Engine Off)see If The You Can Turn The Clutch On The Compressor With Your Hand. If It Turns You Have Either A Electrical Problem Or There Is No Freon In The System. At This Point You Problably Want To Take It To Someone Who Works On A/c's And That You Know And Trust. Most Mechanic Shops Will Charge Very Little To Diagnos A/c Troubles. Good Luck But Beware,most Mechanic Shops Know That Most People Don't Know Anything About A/c Systemsand Will Try To Take Advantage Of That.
Benny
Old Oct 2, 2005 | 09:23 AM
awaken96's Avatar
I had the same problem with mine, turned out to be the compresser, about 800. using the GM parts, works great now
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
