ac box delete
ac box delete
quick question.. i got the ac delete plate and went to pull the box off today. i pulled out all the bolts i could see, and couldnt take the box off. i see theres some comming thru from the inside, do i have to pull those too or am i missing something? i thought you could pull the box from the outside? thanks guys!!
yes there are hidden bolts on the inside and outside some are covered with hard sound material. after you take the 12 or 14 bolts that hold the evap case then right in the middle there is 1 hidden bolt in the engine compartment right in the middle, it holds the heater case thats attached to the evap case. try that and if you still have issues ill get you some pictures
Aaront810
Aug 29, 2020 09:34 PM
karpetcm
Sep 29, 2015 10:08 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
Sep 11, 2015 09:44 AM
