95 Z Factory alarm/ keyless entry HELP
Old May 30, 2004 | 08:01 PM
BackInBlackZ28's Avatar
My car has had the factory keyless entry since i got it, but no alarm. While i was installing the wiring for a light for my CSI pump, i found the factory alarm box under the steering column pannel. It had one of the harnesses disconnected, and when i plugged it back in, the alarm would sound! The only problem is the key fob that i have that unlocks my doors will NOT shut off the alarm. Is there another one i need to get to make this work or is there some way to program it? Help please!
Old May 30, 2004 | 08:23 PM
Aparently its not a "factory" alarm because its mounted under the sterring wheel and it is tapped into a bunch of lines. It is manufactured by GM however. any ideas?
Old May 31, 2004 | 02:25 PM
Someone has to know about this stuff!?!?
Old May 31, 2004 | 03:47 PM
hurricaine418's Avatar
i have the same issue with my '00. can you use the panic button to sound the alarm?
Old May 31, 2004 | 11:07 PM
the alarm is disconnected, i cant sound it all unless i plug it in, in which case i cant shut it off.... Thast why i ned to find out where to aet a remote or whatever i need for it.....
Old Jun 1, 2004 | 05:08 PM
montytrmpt's Avatar
I have a 94 coupe I rewired after a fire and I used a dash pad from a car with a factory alarm. It has a little red light to the right of the top defroster duct. It is definately factory and I would imagine that it was common on all cars with a factory alarm. I would watch out too. The camaro I rewired had what looked like an aftermarket alarm wired in under the column. There wasn't much left so I couldn't ID it positively. (it may have caused the fire.) Also, I believe the wireless receiver for the door locks is going to be under the passenger kick panel. You might take a look there for some clues.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
Stephen68
Oct 16, 2015 03:50 PM
football4life
Oct 4, 2015 07:48 AM
