94 z28 with security light?
Re: 94 z28 with security light?
What rob means is for the remote start to properly work you will have to either have the vatts (passkeyII) either tuned out of your pcm or you will have to do the vatts bypass. Robs site has a great write up on bypassing the vatts system. Check out these 2 links.
http://shbox.com/1/pass_key.jpg
http://shbox.com/1/vats_bypass.jpg
what the Vatts (passkeyII) does is it dissables your fuel pump and starter if it does not see the correct resistance from the "chip" on your key. This stops people from hotwiring your car if they try to steal it. the only way to crank the car up with the vatts working is to have your key (the one the vatts module is programed to" in the ignition.
I would suggest just following robs write up on bypassing the vatts. Or you can spend the $$ and have it tuned out of the ecm.
yes rember to solder it in. anything but soldering it can cause rf noise and / or a diffrent ohm reading thus sending a false signal to the vatts module and throwing the security light and dissableing the car.
Jan 5, 2015 07:14 PM
fpete1992
Dec 11, 2014 03:51 PM
