86' z28 aftermarket tach help
Old Jan 12, 2014 | 12:29 AM
Tman312's Avatar
Unhappy 86' z28 aftermarket tach help
Hello,
So, I just hooked up a Sun Super Tach II to my z28 and when it is grounded, the tach. pins past 8k rpms. Once I un-ground it, it drops back to zero.
The light works, and it must be getting power because it did move.
This is how its setup:
Ground is grounded to body
Signal is from the white wire on the coil
Light is straight from battery, but has a switch to toggle on/off.
Power is straight from battery
What could be wrong?
Old Jan 12, 2014 | 08:10 AM
JakeRobb's Avatar
Super Moderator
Re: 86' z28 aftermarket tach help
Two thoughts come to mind: bad ground, faulty tach.
Old Jan 12, 2014 | 11:37 AM
Tman312's Avatar
Well...Ive taken the ground wire and touched it at different places, with the same result. (even the battery ground post.
The tach is old, my uncle gave it to me a while ago and I think he had it in storage for years after buying it from a garage sale or something..
Any other possibility?
Thanks for the reply.
Old Jan 12, 2014 | 08:29 PM
Tman312's Avatar
Ok. Well, switched the power wire and signal wire. Now the tach will stay at 0 until i turn the key to on or when I start it. The tach moves a bit, but I think I have the wrong wire spliced on the coil.
There's a white and black and a pink and black one I think, its spliced into the white one. Is this correct?
2.8l V6
Old Jan 14, 2014 | 08:03 PM
frankzlt1's Avatar
Green wire goes to the coil black wire is your ground red to the 12v blue to the back light.
Old Jan 14, 2014 | 08:54 PM
Tman312's Avatar
Yes I know but on the coil wires, which one do you get signal from?
Old Jan 21, 2014 | 09:27 PM
Tman312's Avatar
bump
CamaroHeed
Mar 18, 2020 09:50 PM
mr28
Apr 20, 2016 05:44 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
