4th Gen wiper motor rattles- vibration
I have a 1995 Z28, all stock with just over 86k original miles. The pulsemodule went out and I replaced it. The wiper motor itself is original andseemingly works fine. However -- thewiper motor vibrates / rattles; but, only when the engine is running. It is anelectrical induced rattle. I traced this down one afternoon. At first I thoughtit was the linkage or spring around the top of the motor where the linkage ballsnaps over. I had the car idling and as soon as I plugged in the electricalconnector, there was a slight vibration felt in my finger tips. The wiper arms don’tmove. Unplug the connector - novibration. If the engine is 'off' and the key in the run position, novibration. If I pull the fuse, no vibration with the engine running or not.Nothing can be heard outside of the car but inside it sounds like a like a tin canwith rocks type of rattle. With the engine running, and with the wipers ‘on’ orin ‘delay’ mode; thus, any position where the wipers are not 'parked', there isn’ta rattle noise.
I am wondering if there could be a bad ground with the distributor, fuelpump, or injectors.
Has anyone experienced this before? Ihave been searching but have not found anything this unusual.
Thanks in advance.
Thanks in advance.
ChrisFrez
Dec 7, 2014 11:32 AM
Jul 4, 2005 05:00 PM
