4th gen RPO
4th gen RPO
i need to decode these RPOs but all i can find is 3rd gen decoders. does any1 have a link to a site that decodes '95 codes?
codes are as fallows
AG1 AK5 AR9 AUO AU3 A31 A90 B35 CC1 C49 C60 DE4 DG7 DL5 D82/DB2, FE2 FE9 GU6 G80 IPB J1F J65 KC4 KG9 K34 LT1 MM6 MN6 NA5 NP5 N96 QFZ R7A STE T96 UB3 U1T U65 U73 VK3 VM3 V73 Z28 1AY 1SK 12B 12I 6HD 7HD 8TH 81U 9TH
Re: 4th gen RPO
nvm i got em
AG1
ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AK5
RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9
SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3
LOCK CONTROL, SIDE DR, ELEC
B35
COVERING, REAR, FLOOR MATS, CARPETED INSERT
C49
DEFOGGER, RR WINDOW, ELECTRIC
C60
HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
CC1
ROOF HATCH, REMOVABLE PANELS, GLASS
D82
PAINT, SPECIAL
DE4
SUNSHADE, REMOVEABLE HATCH ROOF
DG7
MIRROR O/S, LH & RH, REM CONT, ELEC, PAINTED
DL5
DECAL, ROADSIDE SERVICE INFORMATION
FE2
SUSPENSION SYSTEM, RIDE HANDLING
FE9
CERTIFICATION, EMISSION, FEDERAL
G80
AXLE POSITRACTION, LIMITED SLIP
GU6
AXLE REAR, 3.42 RATIO
J1F
BRAKE PROVISION SPECIAL TO SUIT FOREIGN REGULATION
J65
BRAKE SYSTEM, PWR, FRT & RR DISC
K34
CRUISE CONTROL, AUT0MATIC, ELECTRONIC
KC4
COOLING SYSTEM, HEAVY DUTY ENGINE OIL
KG9
GENERATOR, 140 AMP
LT1
ENGINE, GAS, 8 CYL, 5.7L, TPI, HO
MM6
TRANSMISSION, MAN 6 SPD, BORG WARNER
MN6
MERCHANDISED TRANS, MAN 6 SPD PROVISIONS
N69
WHEEL, 13 X 5, 12 ROUND HOLES
NA5
EMISSION SYSTEM, FEDERAL, TIER O
NP5
STEERING WHEEL, LEATHER WRAPPED
NP5
LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
12B
TRIM COMBINATION, CLOTH, GRAPHITE (B) (92)
12I
INTERIOR TRIM, GRAPHITE (92)
1AY
STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR)
81U
PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
8TH
SUSPENSION-COMPUTER SELECTED, RR, LH
9TH
SUSPENSION-COMPUTER SELECTED, RR, RH
N96
WHEEL, 16 X 8, CAST ALUMINUM
T96
FOG LAMPS - FRONT
U1T
RADIO, AM/FM STEREO, SEEK/SCAN, COMPACT DISC, HPS
U65
SPEAKER SYSTEM, 6, DUAL FRT DASH MTD, F/D, DUAL
U73
ANTENNA, FIXED, RADIO
UB3
CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
V73
ANTENNA, FIXED
V73
VEHICLE STATEMENT, USA/CANADA
VK3
LICENSE PLATE, FRT MOUNTING PKG
Z28
MERCHANDISED PKG, SPECIAL PERFORMANCE
Camarosource.ca's
FULL GM Vehicle
RPO Database List
RPO Description
12B
12I
1AY
81U
8TH
9TH
AG1
AK5
AR9
AU3
B35
C49
C60
CC1
D82
PAINT, SPECIAL
DE4
DG7
DL5
FE2
FE9
G80
GU6
J1F
J65
K34
KC4
KG9
GENERATOR, 140 AMP
LT1
MM6
MN6
N69
NA5
NP5
NP5
12B
12I
1AY
81U
8TH
9TH
N96
T96
FOG LAMPS - FRONT
U1T
U65
U73
UB3
V73
ANTENNA, FIXED
V73
VK3
Z28
Camarosource.ca's
FULL GM Vehicle
RPO Database List
RPO Description
12B
12I
1AY
81U
8TH
9TH
NewsBot
Sep 15, 2015 11:53 AM
detroitmuscle
Jul 31, 2015 04:21 AM
