4th Gen Front Speaker Covers
Old Feb 11, 2008 | 08:40 PM
Need4Camaro's Avatar
Can you remove the front speaker covers on the doors or do I need to take the entire door upholstry apart to access the speakers?
Old Feb 11, 2008 | 08:47 PM
97'Z-28's Avatar
I'm pretty sure you can access the speaker by taking off the covers.
Old Feb 11, 2008 | 09:08 PM
moroso99's Avatar
ya the covers come right off, takes a lil bit of pressure though
Old Feb 12, 2008 | 10:41 AM
JenzZ28's Avatar
Correct me if I'm wrong, but you DO have to disassemble the entire door panel to access the door speakers. If you try to take off the speaker covers they will crack.
The other four speakers in the car just come right off, and snap back into place.
Old Feb 13, 2008 | 07:43 PM
lastZ's Avatar
do not take the speaker covers off they WILL break
Old Feb 13, 2008 | 08:55 PM
Unfotunately... ...I've come to find the conclusion that you're right... Broke the Driverside one... ....well cracked it somewhat anyway...
Old Feb 23, 2008 | 12:14 PM
twalker1190's Avatar
Ya i broke mine too, i dont really understand why they dont come out. 3 of my sides popped out like it was going to pop right off, however the top part of the cover was permanently attached? i didnt understand that.
Old Feb 23, 2008 | 06:19 PM
Quite honestly, nothing GM does makes any kind of sense nor do I believe it makes any kind or logic... Like why the whole motor is sitting closer to the passengerside fender than the driverside and do I need to go on?
Old Feb 24, 2008 | 09:18 AM
sick94's Avatar
took mine off a thousand times on my camaro and firebird and my mother's camaro and they have never broken. they are made of a filmsy plastic that bends without a problem.
Old Feb 24, 2008 | 03:11 PM
On the front? You certain? They're bonded onto the door. The side has latched but the top and bottom of them are literally bonded to the door... I broke mine trying to get it off...
Old Feb 24, 2008 | 03:20 PM
Projectcam94's Avatar
x2
Ive done to my old 94 camaro and this 95 and neither brorke or gave me a hard time.
Old Feb 25, 2008 | 06:08 AM
sick94's Avatar
I have noticed on some f-bod's that the speaker covers have a glue of some type ontop of the latches to help hold them on. Maybe i've just been lucky enough that they have never broke on me when first pulling them off.
Old Feb 25, 2008 | 07:12 AM
shock6906's Avatar
On my 93, they popped right out with no problem (before I switched to T/A door panels) but on my 97, they're bonded in. If you pull the door panel off, you'll see that they melt down a plastic tab to adhere it in. You can cut it out with a Dremel to make it removable, but it still won't be big enough to get the speaker out. To get the speaker out, you must remove the door panel.
Old Feb 25, 2008 | 06:12 PM
stylinbeaver's Avatar
My 94 popped right off no problem. They actually WILL come off. All I had to do to access my speakers were pop off the covers and pop off the bottom door panels tabs. Never had to take the whole door panel off.
Old Feb 25, 2008 | 08:40 PM
Interceptor1's Avatar
On my '96 they come heat bonded to the rest of the door panel, the whole door is constructed like that. A prong goes trough a slot and then they melted it over to secure the 2 pieces together. I found out now that I'm replacing the vinyl and carpet on the doors with synthetic suede. the way to remove it is to cut the plastic from behind and carefully pry the pieces apart, that's how I removed the 2 panels I had to recover.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
CARiD
Feb 9, 2015 09:35 AM
MJ_Z28
Aug 8, 2002 09:02 PM
Zomie
Jul 22, 2002 07:43 AM
