450rwhp on tha street???
....based on that comment I would say you wont have to worry about the gas mileage all that much because if you are just looking to build the fastest car in school chances are you are in it for the fame and not the fun and will crash in less than a month being stupid............
not really for bein 18 I AM A SAFE DRIVER ON THA STREET and no i want this car for fun...not fame...iv always wanted a fast third gen and this is ma chance to have one....im building tha motor myself and yes i kno a good bit about engines...my dads and grandpaw are both mechanics...u should really get to kno somebody before knocking them
.....but thats just my 2 cents
I didn't say anything about 383" motors on my post. I stated Gen 1 SBC's on pump gas. And yes they have those. Don't start a pointless pissing match like you have done on some of the other threads.
Last edited by 95firehawk; Jul 17, 2007 at 12:14 PM. Reason: Emailed OP to clarify.
hold up, ma buget is around 4 or 5 grand.....double that because my moms payin for half so around 9 or 10 grand. and i dont wanna wanna buy a crate motor i wanna build this myself....and i might consider FI if i can find a resonable setup for a resonable price..
He stated he wanted a 383" motor, as he had the 350 block already. And what Mustang are you talking about!? Pointless pissing match... We were having a discussion on a 383 motor when you come in talking about $10K 400+ ci engines and fictional Mustangs
to the origional poster:
it CAN be done, my buddy just built a 383 for his truck that should be around 430 at the wheels IIRC.
If you can run high 10.x:1 compression and a 230s duration cam, you can run 11's.
this is what i would do:
and a price of what it will cost (approx)
ARP head bolts - 60
accessory bolt kit - 75-80
comp cams mech roller camshaft (cca-12-000-9) 300
roller lifters - 350ish
pro magnum rockers - 280
hi-tech pushrods - 130
guideplate - 25
1.550 inner fit valve springs - 300
11/32" super locks - 25
rocker arm studs - 63
edelbrock victor jr. aluminum heads (bare w/ valves) - 1150ish
victor ram tunnel intake manifold
w/e your machine shop does for work and such for the short block - say 3k
then you just need retainers - 100ish
valve covers, balancer, timing chain, oil pump, oil pan, and some other things, and you could get to the 450 RWHP mark more than likely, if not - REALLY close, but you would have to rev to 6500 or so
also, that would be probably a 7k setup, but you can do it cheaper with used parts n such
