2002 Z28 gas filler tube
Old Jan 9, 2008 | 06:39 PM
460 Maverick's Avatar
Does anyone now for sure if it is possible to siphon fuel from the filler tube?
Al 2002 Z28
Old Jan 9, 2008 | 10:12 PM
tom2's Avatar
I believe the filler tube goes across the inside of the tank, not just to the edge. Best bet is to uhook a fuel line and power up the pump and pump it out.
Old Jan 10, 2008 | 09:43 AM
Green96Z's Avatar
I wouldn't do that, you can damage the pump by running it dry. And yes, you should be able to drain the tank with a siphon pump. Just make sure you don't break that little metal door on the filler tube.
Old Jan 10, 2008 | 12:54 PM
JohnD's Avatar
When I tried that on a '97 Transam, there was a screen in the neck down at the bottom that prevented it.
Old Jan 10, 2008 | 09:18 PM
Tried to siphon it today. Hit something in the filler neck about 22 inches down. Ended up pulling the line off the filter and jumping the fuel pump socket.
Al
HectorM52
Jul 30, 2017 11:46 AM
Deadbolt24
Jan 19, 2015 01:29 PM
The Seer
Nov 24, 2014 07:59 AM
squarehead
Nov 21, 2014 08:02 PM
