2.5" or 3"?
2.5" or 3"?
I want to put true duals on a 95' lt1. the car's motor is stock except for a few bolt-ons. I'm want to run long tubes without cats, and probably flowmaster super 40's with an "X" or "H" pipe. I would like to use 3" but i dont know if that is 2 big since im not going to have cats, at least at first. so should i use 2.5" pipe or 3" alright for my true duals. I do plan to add alot more power to the motor soon afterword, but not sure how long it will take due to budget. Any other suggestions to make my exhaust better would be appreciated.
Re: 2.5" or 3"?
Well the long tubes will more than likely have 3in collectors, so unless you want to put adapters right after the collector I would go 3in but with 3in you will be losing more ground clearance
Re: 2.5" or 3"?
agreed...unless you're making 400+hp at the wheels....you'll probably not lose any power going with the 2.5"
but you'll gain good clearance with it.
and i'm gonna suggest going with something like the magnaflow 4x9" mufflers. great sound, great flow and inexpensive.
Re: 2.5" or 3"?
Originally Posted by Fawkes
IMO, for a stock engine, I'd go with the 2.5". I wouldn't worry about the 3" until you get into the 400+ HP range.
