1st time at track and ran 15
Old Jul 2, 2005 | 09:35 AM
Terran2k's Avatar
Well went to the track for the 1st time last night and ran a 15, kinda a downer. ah well here's my time slip so you all can take a look see.
reaction - 1.0735
60ft - 2.35
330ft - 6.46
1/8 et - 9.767
1/8 mph - 74.94
1/4 et - 15.00
1/4 mph - 93.95
Old Jul 2, 2005 | 10:09 AM
LT1-Z's Avatar
Re: 1st time at track and ran 15
if you would have had a quicker reaction time you'd be in the low 14's. but otherwise cool
Old Jul 2, 2005 | 10:45 AM
Z28WannaB's Avatar
Don't listen to the above post, that guy has no idea what hes talking about. Your reaction time has no impact on your time.
Your 60 isen't the best, but it looks like you probably need a tune up because even with a 2.0 you wouldn't break 13s.
- Z28WannaB
Old Jul 2, 2005 | 11:00 AM
Kataklysm's Avatar
Reaction means nothing to your time as previously stated. For the 2.3 60' you should be pulling in the 14s however.
Old Jul 2, 2005 | 12:06 PM
Pandamonkey's Avatar
Got 2.73's?
Old Jul 2, 2005 | 12:16 PM
Kris93/95Z28's Avatar
First, before you over anylyze this: The biggest factors in performance for most lighly modded street cars are weather, and driver. I don't know about the driver part, BUT, what was the weather like when you ran?
Since you most likely won't know, I would use use this website:
It will give the weather conditions for a city at a certain time of day:
http://www.weatherunderground.com
Once you have the temp, humidity, track altitude, and pressure:
Punch those numbers into this calculator:
http://www.modulardepot.com/density.php
This will give you a corrected time.
BEFORE I GET FLAMED TO DEATH:
I wouldn't go about quoting this time as the time you run, I would simply use it as a tool to see if you fall into the normal category for what you car would expect to run under optimal conditions.
Let us know what it turns out to be...
Old Jul 2, 2005 | 12:28 PM
sprayedtransam's Avatar
^^^Good call.
Old Jul 2, 2005 | 08:08 PM
Terran2k's Avatar
Hey, you all are so helpful, the results i got from that website were
Temp: 86°
Humidity: 58%
Track Altitude: 600 feet
Pressure: 29.85 in.
Density Altitude = 2854 feet ET MPH
Uncorrected 15 @ 93.95
Corrected 14.5 @ 97.09
plugs/wires have 10k on them, coil has about 8k on it,fuel fiter 7k, maybe if I had better tires I'd pick up the extra few tenths?
Old Jul 2, 2005 | 08:36 PM
Paul87's Avatar
Don't be let down on a 15 second timeslip, I ran a 15 flat because my tranny won't engage 2nd gear
Old Jul 2, 2005 | 08:58 PM
MustangEater82's Avatar
You need to do something to get your mph up... the weather and altitude wasn't that bad...
did you let off before the end of the track?
aren't stock lt1s trapping like low 100 mphs?
Old Jul 2, 2005 | 09:16 PM
Terran2k's Avatar
I was pedal to the metal from start to finish, I dont know what to think...
Old Jul 2, 2005 | 09:45 PM
Donohue96M6Z28's Avatar
my 1st 94 z28 120k miles, stock, ran a 14.5, beat my friends 03 gt with a few bolt ons , how many miles are on ur car? run strong? i think you can pull low 14's, high 13's under the right conditions if ur car is still a strong runner, did u only run it once?
Old Jul 2, 2005 | 10:39 PM
Terran2k's Avatar
yeah i only ran once, got to the track kinda late, and there was some sort of motorcycle competition going on. its got 79000 miles on it and it feels strong, but i havent rode in any other fbodies to compare...
Old Jul 2, 2005 | 10:53 PM
1993CaMaRoZ28ofIdAhO's Avatar
130000k on mine my first run was 14.527
Old Jul 2, 2005 | 10:54 PM
LT1-Z's Avatar
- Z28WannaB
I guess nobody can take a joke....
