1994 Firebird?
I know it's not a Camaro, but i wanted to find out how much i can get for my Firebird with the condition it is in. It has the Lt-1, but it needs a new water pump driveshaft installed (already have it) i also have a brand new water pump, timing chain, and distributor for it. The body isn't too pretty. Bent up hood (i have a new one, just needs paint) the drivers side fender is cracked, and the nose cone is damaged. I was asking $3,500 for it. But i don't know if thats too much for all the work it needs.
I got my 96 Camaro with 90k with no major problems for $4200. I would say your car is worth 2k or less unless it has like 20k miles on it. Painting a hood and fender would eat up around 1k or more of your buyers budget, and putting on a new WP drive shaft would probably cost $300 to $500 at a mechanic.
Not trying to be mean, but if you want to pull $3500 out of it, you would have to have it completely fixed. You may then be able to get $4k for it.
2K you might find, given the right buyer. You'll have a better shot, if you can get the repairs done yourself. It puts you in a bind though, because you won't get back whatever you spend on the labor to install the parts, unless you have a buddy or someone that can do them for you.
