Unknown Part under intake elbow
So was checking my oil and came across this (picture will be in post) I am not sure what this is and if I need to plug it, it' hard to tell from other pictures what this ishttps://cimg4.ibsrv.net/gimg/www.cam...18ba7c1ea0.jpgUnknown part
Re: Unknown Part under intake elbow
It' pretty lame but I cannot find how to do signature, but I have a 1995 z28 with lt1, longtubes, cold air intake, and I have no cats, long tubes to y pipe, to flowmaster muffler. And like I said its' under the intake
Throttle body coolant pipe.
There is another on the other side. Look up throttle body bypass mod. Mitch |
Did you follow instructions in this post:
https://www.camaroz28.com/forums/lt1...nature-879835/ If you still have a problem, PM me the text you want for the signature, and I should be able to add it to your profile. |
Shoebox has the TB bypass procedure for 95-97. Appears someone already did it.
http://shbox.com/1/tb_bypass.jpg A vacuum cap on each pipe cleans it up. Not necessary, though. Dyno tests of TB coolant bypass - 6 free HP. Modifications #8 Caution for 93/94 owners - slightly different procedure. |
