Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
tech issues
Old Oct 26, 2013 | 04:51 PM
Allen Moravek's Avatar
tech issues
Hi all, I'm in need of some tech help. I purchased a 1994 camaro, with a 3.4L V6. I bought i as a project car, the previous owner replaced the water pump, so the entire front of the block was was torn apart. i reassembled the p/s pump, a/c compressor, tensioner, and alernator. After reconnectioning all the sensors i tried starting it. No go, so i tested the starter, it was locked up so i replaced it. then tried the key, still no cranking, but a clicking under the dash. i tested the battery charge, hooked up jumper cables, a wire the the ignation terminal of the starter. When i touched the wire to the battery, the engine cranked over and it wanted to start when i shot ether in the plenum.
So i read about the resistor trick,found the right one and wired in in the ignition side of the white wires. The engine didnt crank, so i proceeded and located the TDR, bypassed the yellow with the purple. the engine cranked with the key. so i checked the fuel pressure at the intake plenum and there wasnt any. so i located the fuel pump relay, bypassed the pink to gray. i had a good amount of fuel pressure to the engine, itll crank over but it still wont fire.
Can i get some help, please?
Old Oct 26, 2013 | 07:22 PM
Re: tech issues
Have you tried to pull codes?
PROJECT X
Apr 17, 2015 12:13 AM
ad356
Apr 11, 2015 11:12 PM
jackpawt883
Feb 26, 2015 09:04 PM
WildRidez
Feb 23, 2015 07:24 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
