Starter Enable Relay Location on a 93Z
I am looking for the "Starter Relay" or "Stater Enable Relay" location. I'm not sure what the proper name is. I have heard it called both names. Anyway, I know where the fuel pump relay is located. Behind the drivers side kick plate near the hood pull lever. I had this starter relay replaced once before (years ago) for the same symptoms...figured I can do this myself this time. Can someone provide the location for me? Should be an easy swap if I could just find it! Thanks
Re: Starter Enable Relay Location on a 93Z
It is to the right of the glove box, pinned to the metal structure of the dash. The hatch relay is next to it. Remove the glove box, poke your head under and look toward the rear of the car.
