Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Random misfires and vacuum
Old May 21, 2010 | 06:21 AM
MichiganSkip's Avatar
Dumb question.........
How does a vacuum leak cause random misfires?
This is a new one on me and can't understand why vacuum leaks can cause random misfires....
+ when the car warms up, the misfires go away, and the car runs smooth (sometimes)
This is on a 98 V6 Camaro
Skip
Old May 21, 2010 | 06:45 AM
Who said vacuum leaks do that? And if there was a vacuum leak, why would it go away after warmup? Cold engines take a little extra spark voltage. You might look into the plug wires and plugs. You also might want to check what temp the coolant sensor is feeding the computer. The engine might be getting over-fueled if it is skewed to the low side.
Old May 21, 2010 | 11:12 AM
I did a search on here for random misfires and code P0300 and I saw quite a few posts where people say it could be a vacuum leak. That didn't make much sense to me so that's why I ask.
Old May 21, 2010 | 03:50 PM
Doesn't make much sense to me, either.
Old May 22, 2010 | 06:21 PM
byrons1502's Avatar
Vacuum leaks depending on where they are do different things and cause misfires. Most of them causes a lean misfire. Vacuum leaks that are there on startup and get better as they warm up are normally intake gaskets that leak and swell with heat. We get alot of them especially with plastic intakes and rubber gaskets. A vacuum leak on a maf car can cause the airflow grams per second to be low and makes the engine run even leaner than it was before. A vacuum leak on a map sensor car normally causes a high idle.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
