Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Racetronix Fuel Pump issues
Old May 17, 2009 | 08:20 PM
  #31
Ta4life's Avatar
waiting for racetronix to fix it. since you can not buy a bucket new
Old May 17, 2009 | 08:30 PM
  #32
RallyBoy1's Avatar
I may just put seal all where the crack is and put the pump inside the bucket. I cannot wait as this is the only car that i have. Man, this **** sucks.
Old May 17, 2009 | 08:41 PM
  #33
Ta4life's Avatar
for your reference this is a known problem. the pump fits in the bucket fine. its the oring that cracks it because its to thick. i told them they need to use a smaller oring and they said they might have to start including 2 o-rings because some fit..some dont
Old May 17, 2009 | 09:40 PM
  #34
RallyBoy1's Avatar
Originally Posted by Ta4life
the pump sucks from a HIGH pressure. the returned gas goes into the bucket and would suck it
Doesn't the return line have a filter that fits inside the bucket that filters the returned fuel? I just noticed this looking at the bucket. Also, the inlet has a screen around it also. I am not doubting what you have said, I am just trying to see what my options are because I have to get my car back on the road.
Old May 17, 2009 | 09:41 PM
  #35
Ta4life's Avatar
fuel can still swoosh around in the tank into the bucket...id be safe
Old May 18, 2009 | 02:55 PM
  #36
RallyBoy1's Avatar
Racetronix.....Hello?
Old May 18, 2009 | 02:57 PM
  #37
Ta4life's Avatar
did you not call them?
Old May 18, 2009 | 03:08 PM
  #38
RallyBoy1's Avatar
Yeah, I finally got in contact with them. I did not know today was a holiday in Canada so most of the people were out of the office/shop. They are going to take care of the situation. Thank you Racetronix!
Old May 21, 2009 | 11:03 PM
  #39
RallyBoy1's Avatar
Well, I received my new pump from Racetronix today. It does not fit! I had to pay for a used fuel pump assembly just to get another bucket. I don't know if I got a pump from a new batch that they were supposed to be shipping out but the date on my pump says 3-9-09. Racetronix, I am in a desperate situation here as this is my only transportation.
Sean Jones
Old May 21, 2009 | 11:07 PM
  #40
Racetronix's Avatar
Sean Jones
This pump was machined and checked before it was sent out to you. We have a few test buckets here and all was OK. Perhaps we can give you a call tomorrow to find out what is going on. Perhaps there is something missing from the picture here?
Old May 21, 2009 | 11:12 PM
  #41
RallyBoy1's Avatar
How much pressure do I have to put on the pump to get it to seat? Should it just slide in place? If I take the o-ring off, the pump fits into the inlet.
Old May 21, 2009 | 11:16 PM
  #42
Racetronix's Avatar
A VERY small amount of pressure is required. Just enough interference to make sure the o-ring makes a seal.
Old Dec 12, 2009 | 09:59 AM
  #43
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Sorry to bump a somewhat old thread, but I was set on buying this kit. After reading this thread, I assume this is not the pump included with the Racetronix kit, which appears to be the Walbro pump designed to fit in our fuel pump buckets?
http://treperformance.com/i-133147-c...1985-2002.html
Old Dec 12, 2009 | 10:12 AM
  #44
Ta4life's Avatar
infact is the walbro pump....racetronix does not make a fuel pump.
Old Dec 12, 2009 | 10:38 AM
  #45
BTC's Avatar
BTC
I understand that Racetronix doesn't manufacture the pump. I'm just curious whether that is the particular Walbro pump that's included in the Racetronix kit. The Walbro pump I linked to appears to be designed to fit our fuel pump buckets, and appears to have an offset fuel inlet. There are a lot of comments in this thread about the Walbro pump used with the Racetronix kit having a centered fuel inlet.
