Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
New Fuel Pump
Old Feb 9, 2007 | 05:05 PM
Zachz28's Avatar
New Fuel Pump
Is it possible to get just the fuel pump with out buying the entire assembly after market or otherwise? And if so were?
Old Feb 9, 2007 | 05:10 PM
2000GTP's Avatar
Sure, pick up the Racetronix pump. http://www.thunderracing.com/catalog...vid=4&pcid=166
Old Feb 9, 2007 | 05:28 PM
Zachz28's Avatar
any stock replacements that cost less? or is that as good as it gets
Old Feb 9, 2007 | 05:33 PM
OBE1 95Z28's Avatar
There are fuel pumps that are close to a stock replacement but they don't fit well in the stock fuel bucket. I installed a Walbro 255 lph pump and it was a pain in the ***. Some people ditch the fuel bucket, but this bucket serves a purpose (you can read about it on the Racetronix site). If I had to do it over again, I would have gone the Racetronix route. The extra few dollars is worth it for the easier installation. I helped a friend install the Racetronix kit and it's a much better solution.
You don't need to spend the money for the upgraded wiring harness if you have near stock fuel demands.
Old Feb 9, 2007 | 06:56 PM
Zachz28's Avatar
What about the holleys?
Old Feb 9, 2007 | 07:02 PM
2000GTP's Avatar
I believe the Holleys are a direct replacement for the third-gens. I'm not sure how they would work on the 4ths.
Old Feb 9, 2007 | 09:46 PM
NikkiLynn's Avatar
This is also what I was told.
Old Feb 9, 2007 | 10:02 PM
mdacton's Avatar
I used aBBK from summit in a 4th gen worked fine, fit in the bucket fine...its just a walbro 255 in different packaging
Old Feb 9, 2007 | 10:09 PM
Kevin97ss's Avatar
According to that page the racetronics system uses the Walbro 255L/Hr pump.
Oops, sorry 2000 GTP, I meant to quote OBE1 95Z28 to point out your link.
Old Feb 10, 2007 | 07:05 AM
SS RRR's Avatar
The bucket also has to be modified to fit.
Old Feb 10, 2007 | 07:07 AM
SS RRR's Avatar
Link?
Old Feb 10, 2007 | 09:19 AM
2000GTP's Avatar
It used a Walbro pump, but it is modified in such a way that it drops right into the bucket without having to modify the bucket itself.
Old Feb 10, 2007 | 01:22 PM
Zachz28's Avatar
how does the bucket have to be modified?
Old Feb 10, 2007 | 02:50 PM
2000GTP's Avatar
You need to shave the ribs on the inside of the bucket a little bit.
Old May 18, 2007 | 06:22 PM
ashakeandfrys's Avatar
On mine I had to replace the O ring, since it was a tad bit too big. Not bad, an extra 30 cents from True Value.
