Sure, pick up the Racetronix pump. http://www.thunderracing.com/catalog...vid=4&pcid=166
There are fuel pumps that are close to a stock replacement but they don't fit well in the stock fuel bucket. I installed a Walbro 255 lph pump and it was a pain in the ***. Some people ditch the fuel bucket, but this bucket serves a purpose (you can read about it on the Racetronix site). If I had to do it over again, I would have gone the Racetronix route. The extra few dollars is worth it for the easier installation. I helped a friend install the Racetronix kit and it's a much better solution.
You don't need to spend the money for the upgraded wiring harness if you have near stock fuel demands.
Quote:
According to that page the racetronics system uses the Walbro 255L/Hr pump.Originally Posted by 2000GTP
Oops, sorry 2000 GTP, I meant to quote OBE1 95Z28 to point out your link.
It used a Walbro pump, but it is modified in such a way that it drops right into the bucket without having to modify the bucket itself.Originally Posted by Kevin97ss
On mine I had to replace the O ring, since it was a tad bit too big. Not bad, an extra 30 cents from True Value.
