Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Mallory Dead again???
Old Jul 11, 2007 | 10:13 PM
Moshbmx1's Avatar
I was coming home from work tonight all of a sudden as i was starting to accelerate up a hill the car lost all power. The first thing i check is the Mallory and its still on.. so i go under the hood and put the ignition back to stock and it fires right up. Ive already had this go out early this year and have only put maybe 500 miles on this new one. Anyone else had this problem with the 685?
Old Jul 11, 2007 | 10:21 PM
seawolf06's Avatar
I had one go bad supposedly cause it was in the glovebox and overheated. Where is yours?
Old Jul 11, 2007 | 10:42 PM
Moshbmx1's Avatar
Same. Im going to call Jegs tomorow and see if they can replace this one and then remount it back in the hatch behind the sub.
Old Jul 12, 2007 | 05:59 AM
joe-96z1le's Avatar
I failed a Crane Hi-6 box after about 600 miles. It was mounted in the engine compartment so I assume it was heat related. The next one lasted much longer mounted in the car on the passenger side kick panel.
Old Jul 12, 2007 | 04:37 PM
seawolf06's Avatar
On the kick panel up front? I ask because I was worried about putting it there in case the heater core breaks and coolant gets leaked into that area.
Old Jul 12, 2007 | 10:00 PM
Moshbmx1's Avatar
Called Jegs they said send it back and get another one...lets hope it last longer in the new spot.
Joe, do you have any pics of it mounted?
Old Jul 13, 2007 | 06:31 PM
FireChicken1995's Avatar
hummm thats garbage, i had my 6A box in my truck engine bay for bout 3yrs and then in the TransAm engine compartment for about 7 months and its still going strong.
Old Jul 13, 2007 | 07:19 PM
seawolf06's Avatar
I don't know if it makes a huge difference or not, but the Mallory does have a lot more circuitry and digital components that could be much more susceptible to heat. It's not quite as simple as the MSD 6 series.
Old Jul 16, 2007 | 04:35 PM
2000GTP's Avatar
I haven't had any problems with mine, but I purposely mounted it in an open location so it gets plenty of airflow. Even in the open, I've noticed it gets pretty warm, I can only imagine how warm it can get it confined spaces or in the engine bay.
Old Jul 29, 2007 | 08:45 PM
Sinister95Z's Avatar
I mounted my 685 in the nose of the car where the wiper fluid bottle used to be. It got plenty of airflow and always seemed to run pretty cool. I had to send my box back to Summit due to failure. One day I was just driving down the road and then all the sudden the car just stopped running. Since I got the new box, everything has been fine. (So Far)
n2oblkz
Oct 22, 2015 02:31 PM
dylan1303
Aug 12, 2015 02:00 AM
'96Z28
Jun 30, 2015 05:46 PM
dylan1303
May 22, 2015 12:24 PM
